Precision low reference voltage
flote21
Advanced Member level 1
Hello guys,
Im my current desing I have the next 2V reference voltage
However I need to exchange it by a 0.5V reference voltage. I was checking in Digikey and I did not found any commercial part with such a low value. Could use a Zener to get this low value? I am afraid the zener is not giving me the enough accuracy: +-1%...
Note: It would be great to find a part with the package: SOT-23.
Greetings.
KlausST
Super Moderator
Staff member
Advanced Member level 7
How much thermal drift can you accept?
2mV/°C?
Then a usual diode (1N4148) may produce around 0.65V, A schottky diode (BAT54) around 430mV.
Mind: cathode to GND.
Klaus
    flote21
FvM
Super Moderator
Staff member
Bochum, Germany
An obvious solution is comprised of reference, voltage divider, OP buffer. Buffer may be avertable depending on the load impedance.
flote21
2mV/ºC is good for my application. Thanks for the advice :)
The proposed solution of FvM is goof bu I will need to redesign my PCB....I will try with the normal deiodes.
Thanks,
FvM
Super Moderator
Staff member
Bochum, Germany
There are obvious reasons why precise shunt references below about 1V aren't feasible. You need to switch either to series reference or divide a higher reference voltage.
danadakk
Advanced Member level 5
BigBoss
Advanced Member level 6
Türkiye
Divide the Reference Voltage by Precision Resistors then use an OP_AMP as a Voltage Follower( Low Drift \[ V_{offset} \]Model).
d123
Spain
Thanks,
Due diligence is to check datasheet electrical specifications and relevant graph for forward current versus forward voltage, then check electrical specifications and relevant graph for forward voltage versus temperature - the variation with current is large and with temperature is also quite large, over a small temperature range it might be tolerable, from 0°C to 85°C it becomes undesirable, IMO.
FvM
Super Moderator
Staff member
Bochum, Germany
    flote21
Easy peasy
Melbourne
plain resistive divider off the 2V ref will be fine - buffered by an op-amp if required ....
flote21
do you think a simple divided resistor with 0.1% of tolerance and 15ppm will be enough to keep 0.5Vref at 50ºC? According to the theroy the error is minimum...but I don't know if maybe a diode will provide a better performance...
FvM
Super Moderator
Staff member
Bochum, Germany
You can know. A silicon diode has a forward voltage T.C. of -1.9 mV/K, or about -3000 ppm.
Reactions: d123
    d123
