Precaution for trace from Connector to Filter (input uP pin)
mkbs
Member level 3
About analog noise
Hi to all,
about wiring to analog input uP pin,I put the filter (R-C) close to uP pin ( like described on Datasheet ), but what kind of precaution I have to do with trace from Connector to Filter ?
uP <--FilterRC-------<-------<------ Trace > 100 mm ------------<---------<-----| Connector |
Isn't there noise that can spread over the board ??
uP <--FilterRC-------<--Noise-----<------ Trace > 100 mm ------------<----Noise-----<-----| Connector |
Many Tanks
MBKS :eek:
arturt134
Full Member level 2
Poland
Re: About analog noise
If you have 10 or 12 bit ADC in your uP, don't bother about the noise. The RC filter is enough.
If you have 16 or more bits resolution..... you have to look in the book about grounding
Vicent Yang
Member level 5
Taiwan
To keep the signal noise free, you should run the signal between two ground lines to avoid any crosstalk from the adjucent pcb tracks. Also if you passed the signal through a ferriete bid on entering the card this will help also to receive a good signal to the up I/P. If you need another help ask.
