for design the comparator, usually add a pre-amplifer to amplife the input signal to speed up the comparator. the comparator in the figure is a wide-spread one, but how to add a pre-amplifer to the compatator, here i will use it in the pipeline adc , the comparator will judge the +/- (Vref/4). Can I add a pre-amplifier directly to the inputs of the comparator, or some other circuit is useful. any useful paper?
Thank you.[/youtube][/url]
Hi
if u add a preamp before ur comparator, the threshold voltage no longer determined by the backend comparator, but determined by the pre-amp.
so u must set the threshold of ur pre-amp at VREF/4. this is my opinion !
One possible suggestion on this is to split reference subtraction and positive-feedback slicer.
If you use a cell to do reference subtraction, and then restore full-logic level of the subtracted signal. Between them, you can do pre-amplification of the residue.
