Pr0tel dxp schematic Title Block: how?
cbsirio
Member level 3
dxp schematic
Hi all!
I was using the trial version (with service pack 2) of pr0tel dxp, but in the schematic I cannot set the title, neither "Revision" neither "Number"... Nothing in the "Title Block" can apparently be set...
Can someone help me, please??? :cry:
Thanks all
Sirio
title block dxp
There should be a number of special strings in the title block area such
as =organization, =address1 and such. These will remain that way until you print unless you have convert special strings turn on in the schematic
preferences.
You set what you want to appear for these special strings in the menu Design>Document Options>Parameters (value column).
dxp schematics
Ok, right, there are some special strings to set (=TITLE, etc...), but, it's not clear...
I remember OrCAD: I set the title properties, and then I see my properties in the title.
Now, in Protel, I set the special strings, in "document options" - "parameters", but nothing goes...
I set the title in "ANSI" and no effect (it become ANSI, but no strings), then I reset to "Normal", and nothing again...
The title area is EMPTY... :( None of the special strings appears to have effect in the title area.
If I place a Text and set it to "=DATE" ok, it works, but the title itself doesn't have a built-in text ????????
Thanks again.
Sirio.
related:proteluser.com/viewtopic.php?f=30&t=3696
how to creat schematic Title Block by myselft in pr@tel dxxp???
title block in dxp
YOU SAID-
The title area is EMPTY... None of the special strings appears to have effect in the title area.
If you look at my first reply, you see that I said to set preferences to "convert special strings" to get the special strings to display. When you do that the =title will show whatever you have entered into the Document Options>Parameters.
i.e. -- Tools>Schematic Preferences>Graphical Editing> (check the box for "Convert Special Strings")
