Powr supply of operational amplifier
penghan
Member level 4
Shanghai
Dear all,
For some operational amplifiers, only one positive power supply +VCC is used in the design. But for some other operational amplifiers, both +VCC and -VCC are used in the design. Then, what is the difference of the application of these two amplifiers?
THX,
Rogrec
One supply is more economical but the signal has to be unipolar. You need two supplies + and - for bipolar signals with no DC offset.
Then why not use AC couple or level shifter to boost the DC level of bipolar signal without DC offset in single supply amplifier?
If you´re not worried about DC level you can use both. As posted above, difference is cost only.
Because sometimes you wanted a negative DC signal. That is rare these days. -VCC could be set to 0V if that's the lowest voltage in the system.
It seems that in audio power amplifer application, we need a 0 DC output to drive a small resistor(several ohm range)?
But dual power supply is not a must for audio power amplifier. Isn't it?
