Hi
I am making a pcb in power pcb and have enabled teardrops in preferences but when I route through hole components teardrops dont appear. any ideas???
this can be solved by enabling the setting in the property settings. press ALT + CTL +G
in the teardrop settings set the properties as required and then in "routing" tab select the generate teardrops. this will help u
