PowerPCB file version transfer
eedac
Junior Member level 3
HK
Could a pcb file in PADs be saved as low version?
I have no way to edit/ view PADs 2005 files using POWERPCB5.0:cry:
Export file as ascii (.asc) file then import it in to the powerpcb 5.0. It should work.
thanks.......i will try it!!
I thought it is a text-format file ...like netlist file...
Could it be used for Orcad CIS, or protel, did you do that?:D
eedac said:
Could it be used for Orcad CIS, or P*otel, did you do that?:D
No i didn't. I don't think that programs import .asc file but i'm not sure.
If u want to import to protel, u should export .asc file as 3.5 version(powerpcb).
i tried once but it create errors...........
and failed.
Binu G
There cannot be 100% free from error against different format conversion. The sofware itself also declare this matter.
