Artlav
Full Member level 2
- Joined
- Nov 26, 2010
- Messages
- 144
- Helped
- 2
- Reputation
- 4
- Reaction score
- 2
- Trophy points
- 1,298
- Activity points
- 2,723
I want to get a photomultiplier working. No particular use yet, just to get a meaningful reading off it.
The device in question: http://www.melz-evp.ru/FEU85.html
Connected it as per original datasheet: http://istok2.com/scan/2894_1.gif
R is 100KΩ.
For sensing, there is a 1MΩ resistor before the anode, and a voltmeter across it.
The power supply gives 900V.
Now, the problem is - there is a constant current across the resistor, starting from 90µA, and slowly going down to 60-50µA when powered, climbing back if left unpowered. Maybe further, didn't wait long.
That current is independent of the amount of light coming in.
I tried to get it as dark as possible, knowing the legendary light sensitivity of the device, but there is no change.
The thing is in a black bag in a box, the room is dark, not a single LED left on, night outside - and the current is still the same.
Trying to add more light does not change anything - all the way to leaving it naked in a dimply lit room.
There is no reaction at any reasonable light or darkness.
The question is - what can i be doing wrong?
Are there any guides on how to use a PMT?
Google is not helping, and a few DIY descriptions i found just list what is used without why.
What do the R in the voltage divider define? Would the sensitivity be less or more if i increase or decrease the R?
Can the thing be so sensitive as to be whited out in complete darkness, or is something wrong?
R is 100KΩ.
