Power transformer selection for half bridge SMPS
jegandren
Junior Member level 3
half bridge smps
hello all
I have jus designed a half bridge switching power supply of 300W , switching at a frequency of 100 Khz. now im in the mode of building the prototype...but i am quite blur on the type of power transformer that i should use...can anyone advise me on this matter.
Thank You
half bridge transformer
You can use Ferrite Core 3C85 (E+I or ETD). It can be found in ferroxcube site and by the way this company also introduces 3C94 core. It can be used at this frequency easily. ENJOY
smps transformer calculation
Please give more details, and i can design you a a transformer, and post here the sketch-es.
i need primer voltage, current, and frequency range and secondary voltage.
//www.electronicsoft.net/download/transformer.zip
Heloo sir,
Thank you very much for the reply, this are the details that i could provide you:
The primary voltage would be +168 V to -168V
The secondary voltage would be +56 V to - 56 V
switching frequency 100 Khz
output voltage to the load 25 V
max output current is 12 A
max output power 300W
half bridge power transformer
I calculated for you the transformer's data.
if you unse Kaschke 2004 ferite, you need 110mm^2 area of the core, or above. The primeri winding should have 12 and the secondary winding should have 4 spirals to have +-168/+-56 transformation.
Added after 31 minutes:
You can use Transformer Calculation v0.1.
You can download it from:
    jegandren
Hello, I'm also going to build a prototype of the half bridge converter. I'm a bit confuse with the transformer part. The secondary transformer is 56Vpeak. So the the Vrms is about 40V. How to 25V at the load?
