Power trace vs Power plane
jerry117
Newbie level 1
I've heared two versions. One is that power plane maybe causes noise coupling, and the other is that power trace can restrain noise coupling. Which layout of power is better?
flatulent
Advanced Member level 5
Middle Earth
Successful companies whose products work and pass EMI regulation tests always use power and ground planes. Sometimes several of each.
alphi
Advanced Member level 1
I think it is vary with your application.
large gnd plane is better for esd,but it is worse for emi because of it large loop area.
Git
Full Member level 4
Torino
alphi - surely having a pin go immediately to ground plane is the shortest loop you can get (given that the vcc has the same route in both cases)?
Git
lyric
Junior Member level 1
power plane is better than power traces,because traces will bring more inductence into power distribution system, which will cause ground bounce, EMI, etc, espeasialy for high speed digital system
MentorSI
Newbie level 2
Power plane has a lower impandence and it provides a smaller loop area than power lines.
amjad
Full Member level 5
Power planes are much more better then power traces because it provides better connectivity
