Power supply layout guide....
davorin
Advanced Member level 3
Switzerland
power layout guide
Is there any tutorial/guideline for designing the power supply connections to complex/multivoltage devices like FPGA including copper planes?
Not a problem with multilayer designs I assume...but wanna stick with 2 layers (o;
There is recommended layout and bypass/decoupling capacitors. Do use them.
BRMadhukar
maybe some books about SI or pci design will have
what you want.
maybe it helpful with you--pcb in power
you can download a power IC's Spec,and can get the information what you want.
You must understand your chip's application note about layout.you can request it from FAE.
about current and the trace width relationship 0.1016 mm 155 mA
0.1524 230
0.2032 280
0.254 540
0.508 890
1.016 1450
