Power Supply 0-30 volts 0-5 amper
Jose Fausto
Member level 4
Peru
regulated power supply 0-30 volts
I am interesting in design a power supply, with the next characteristics:
Voltage: 0-30 volts
Amperes: 0-5 amperes
Shorcircuit protection
Good stability
Linear or Switching?, I think linear is most easy, and with low noise....Your opinions?
Jose
0-30 volts
Voltage: 0-30 volts
Good stability
Jose
Use just a little your own brain. For 30V on output you need at least 35V on the input for the lowest main voltage input. Assuming you want 1V/5A from this 0-30V linear supply, the regulator will dissipate 34V x 5A = 170VA.
You need a trick to minimise the power dissipation on the regulator (like a driven bridge, a transformer with many switched output voltages etc) .
Before believing everything is written on the web stay a little on your own feet and think.
30volts transformer
For Power Dissipation problem: It may be possible to step down the main supply by a switching power converter and then fine tune it by a linear regulator!
how to design a power supply of 30 volts
I think I can find so many designs for power supply in the web, but I am thinking in a very good power supply, where the current and volatge regulation must be excelent, and with full protection for people who make several shorcircuit.
I made some designs but allways have some problem, with protection.
Thank You
