Usjes
Newbie level 2
I'd like an explanation of the PSD of a sequence of independent random PAM symbols or amplitude +1 or -1. Now any standard textbook tells us that the PSD is the Fourier Transform of the autocorrelation of the signal, in my case the symbols are INDEPENDENT and => the autocorrelation is non-zero only over the symbol duration 'T', beyond this it goes to zero. Going through the maths I come out with and answer PSD = sinc^2(wT/2), it is basically just the square of the ESD of a rectangular pulse. Again any standard textbook confirms that this is the 'correct' answer. Here is my problem though; sinc^2(wT/2) has a maximum at w = 0, ie it is saying that the most powerful component of the signal is at DC. But if I simply take the mean of my sequence I get zero (the symbols are RANDOM +/-1 and => the average is zero). So, my signal has mean zero (=> zero DC component) yet the accepted 'correct' PSD for this signal implies that its most powerful component is at D.C. Can anyone explain how this can be correct ?
Thanks,
Usjes.
Thanks,
Usjes.
