Power MOSFET STP60NF06
kengloong
Member level 4
Singapore
Anyone could supply myself 8pcs of Power MOSFET STP60NF06 urgently?
Please let me know how much per pieces?
Thanks in advance...
If you can't get STP60s then try to get their equivalents, for example: IRFZ48, IRFP048, SUP75, BUK7508, and so on ..
Try RS Components Malaysia: www.rsmalaysia.com
Regards,
IanP
Thanks for all valuable information.
For your info, I already tried to change STP60NF06 to STP60N06, but the UPS (Unintteruptible Power Supply) is not working. Their is not output voltage in the output point.
So, can you please give me some idea on this.
Once again, thank you.
Regards,
Keng Loong
The "N" part is significantly slower and has higher capacitance than the "NF" part. That difference may or may not cause trouble in your UPS circuit.
Did you replace the MOSFET because it was damaged? Maybe the circuit has another malfunction that killed the MOSFET.
