gon8042
Power map
I've tried to generate power map using SoC Encounter.
But it seems to be impossible to generate a detailed power map inside a block,
though VoltageStorm is able to do power analysis such as IR drop analysis within a block using tools like XTC & Thunder.
The Encounter power tool sees a block as an instance, thus the power is represented by a single number regardless of the size of a block.
I'd like to have a detailed power map for a block to do thermal analysis based on the power map.
Does anybody know how to generate a detailed power map within a block or other tools that can do this?
