[SOLVED] Power management (watchdog) on 18F
bauche
Junior Member level 1
Hi there i found this little example on how to use power management on 16F...i want to use it on 18F2580
with Micro C i cant compile on 18F i think it's option_reg the prob
Can somebody translate the code for use the wdt in 18F?? i want to knows wdt on 18F for future code
Thanks for help!!!
/* Project name: Understanding sleep mode in PIC microcontrollers
* Copyright: (c) Rajendra Bhatt
* Test configuration: MCU: PIC16F628A Oscillator: XT, 4.0000 MHz */
sbit LED at RB0_bit; // LED is connected to PORTB.0
void main()
TRISB = 0b00000000;
TRISA = 0b00100000;
LED = 0;
OPTION_REG = 0b00001111; // Assign 1:128 prescaler to WDT
do
asm sleep; // Sleep mode, WDT is cleared,
 // and time out occurs at Approx. 2.3 Sec
 // Current is minimum in Sleep mode
LED = 1; // After wake-up the LED is turned on Delay_ms(500);
LED = 0; asm CLRWDT; // Clear WDT Delay_ms(2000); // Measure current here and compare with Sleep mode
}while(1); // current
The OPTION REG is not a 18F register - see the 18F2580 Datasheet, Watchdog section, for details of the correct registers /bits
