Power from PC parallel port
msmax
Full Member level 1
Pays Bas
Any one has experience retreiving power from parallel port. I need it to power up minidisk title hardware from LPT.
All your advise is welcome.
Don't try do a such thing! A PC PP haven't got current handling capacity enough to drive a regular motor (seldom beyond 20mA/pin). You only could burn your PP. Nevertheless USB (and only USB as far as I know) is intended to give the power supply needed for regular (medium power) peripherals (ie a minidisc).
Cheers :wink:
Max power available at usb port is 500mA.
Well, first get the pin connection from a search engine, try: https://www.google.com/
2nd use a high current transistor( darlington ) to amplify the current, bcz pc's lpt are current limited by resistor.
good luck
Thanks for your reply.
I only need to drive an infrared LED for sending commands to my MD equipment.
Just made a cable to the PS/2 connector which has a reliable 5V source.
