Power Factor...Zero-crossing
lats
Full Member level 4
Hi friends,
i'm trying to measure "power factor". On internet i read some articles from which i understand that time difference between the zero-crossings of Voltage and Current gives the power factor. But i'm not able to understand how to convert time interval value (lets say for example, time interval = 1 milli Seconds) into Power factor value. Can someone please explain it to me with some example.
Thanks.
Hi Lats,
The ratio between the time difference of the zero crossings and the
period equals the ratio between the measured phase shift (phi) and
the maximum phase shift ( 2*pi radians or 360 deg or 400 grad ).
The rest is algebra . . .
φ = 2*Π*δt/T
cos φ = cos (2*Π*δt/T)
δt = 1 mS
cos φ = cos (2*Π*1*10E-3/20*10E-3) (50 Hz ; 20 mS)
cos φ = 0,951
Make shure that your calculator is set to the "right" degrees or radians.
Note that your calculator may lie a bit when checking extreme values
like 0 or Π/2 radians, rely on your own good judgement.
on1aag.
    lats
there r many other methods to calculate power factor e.g threee voltmetre method etc
thanks on1aag for the help . i have this zero crossing detector ckt but this doesnt work . could u please provide me some appropraite daigram for zero crossing detection..
