Heavenlyrider
Newbie level 5
I am designing a cheap Pic-micro controller based energy meter using voltage divider and hall effect sensor. I can measure the power in KWh for Resistive loads but i need to calculate the power of inductive loads. while surfing the internet, i found that "Power factor" should be measured for calculating the power of the inductive load. But the same time, all the examples given were using the 'zero crossing principle', along with voltage and current transformers. Is there any other method to find the power factor without using VT and CT?
