Power electronic converter duty ratio
Johnjacob
Newbie level 6
I have read from several different sources that the duty ratio for a Cuk converter is
(Vo/Vin)=(-D/(1-D)
but several other sources say its:
(Vo/Vin)=(D/(1-D)
which is the correct one...i'm tad bit confused..
Consider duty cycle to be positive, Then the upper formula is for negative output voltage.
The lower formula gives positive output voltages.
Klaus
Klaus
Hi, thanks your reply. Thanks make more sense...how about if the converter is an Ac/ac cuk converter....would be simultaneously valid?
