katrin
Full Member level 1
power cut cell
For the ESD protection, the technology provides I/O pad and Vdd, Vss pads
there are some power rings across these pads, vdd1, vdd2, vss1, vss2...
these Vdd1. Vdd2 should be connected together through the Vdd pad, the same for Vss
At the same time, I also noticed there are some cells called power-cut cells in the library. I may need to connect all these ESD pads together through these power-cut-cells(I am not sure)
Is it necessary to connect the ESD pads through the power-cut cells? Or can I use parallel metal to connect these pads together directly? can someone help me with that?
