i was wondering how to use properly the potentiometer resistor from BREAKOUT Library.
There's the parameter called "SET="
what is the numaric value/range to set that parameter ?
is it's range 0 to 1 ? means precentage division of two resistors?
for example:
if the potentiometer value 2k, setting "SET=0.5" will divide the potentiometer into two 1k resistors ?
or maybe the SET parameters is the resistance value itself on one of the two so-called divided resistors ?
tried to look for some info about that but found nothing about this parameter.
