prasanthri
Newbie level 1
I have written a code for D-FF in VHDL. When I performed the post-route simulation I got an unacceptable delay in the output. I used a clock of 10 ns period (100 MHz)as the input clock. But the output is changing only about 6 ns after the positive edge of the clock for which it is designed to change. I am using Xilinx ISE for synthesis and Modelsim SE for simulation. Here is the code I have written...
Code
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
---- Uncomment the following library declaration if instantiating
---- any Xilinx primitives in this code.
--library UNISIM;
--use UNISIM.VComponents.all;
entity dff is
Port ( data : in STD_LOGIC;
clk : in STD_LOGIC;
reset : in STD_LOGIC;
q : out STD_LOGIC);
end dff;
architecture Behavioral of dff is
begin
process (clk,reset)
begin
if reset= '1' then
q<='0';
else
if rising_edge(clk) then
q<=data;
else null;
end if;
end if;
end process;
end Behavioral;
Test Bench
LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
USE ieee.std_logic_unsigned.all;
USE ieee.numeric_std.ALL;
ENTITY tb_dff_vhd IS
END tb_dff_vhd;
ARCHITECTURE behavior OF tb_dff_vhd IS
-- Component Declaration for the Unit Under Test (UUT)
COMPONENT dff
PORT(
data : IN std_logic;
clk : IN std_logic;
reset : IN std_logic;
q : OUT std_logic
END COMPONENT;
--Inputs
SIGNAL data : std_logic := '0';
SIGNAL clk : std_logic := '0';
SIGNAL reset : std_logic := '0';
--Outputs
SIGNAL q : std_logic;
BEGIN
-- Instantiate the Unit Under Test (UUT)
uut: dff PORT MAP(
data => data,
clk => clk,
reset => reset,
q => q
reset<='1','0' after 100 ns;
data<=not data after 200 ns;
clk <= not clk after 5 ns;
END;
Code
library IEEE;
--library UNISIM;
entity dff is
clk : in STD_LOGIC;
q : out STD_LOGIC);
end dff;
begin
process (clk,reset)
begin
if reset= '1' then
q<='0';
else
q<=data;
else null;
end if;
end if;
end process;
end Behavioral;
Test Bench
LIBRARY ieee;
END tb_dff_vhd;
COMPONENT dff
PORT(
clk : IN std_logic;
q : OUT std_logic
END COMPONENT;
--Inputs
--Outputs
BEGIN
uut: dff PORT MAP(
data => data,
clk => clk,
reset => reset,
q => q
END;
