jiffyg89
Newbie level 3
- Joined
- Oct 26, 2011
- Messages
- 4
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Activity points
- 1,324
I am replicating an IEEE paper using Low-Power split-path data-driven dynamic logic. Since they are not standard logic blocks I was not able to synthesize it from RTL so I did fully custom schematic and layout by hand. The design is a 16x16 bit multiplier, and the layout passes DRC/LVS without any warnings or errors.
I have ran about 35 random test cases for the schematic netlist and they all pass. The problem is when I run the netlist with the PEX data. Of the 10 cases I ran for the post-layout simulation, 6 of them passed and 4 of them failed. The 4 failing test cases do not seem to be related i.e different bits are returning bad data on each of the tests. I have already tried increasing the evaluation time (giving it 4x longer to evaluate than it actually takes), and they still do not pass.
What I am thinking about next is to try the following:
- Adding extra nets/pins to large fan-out nets to decrease the parasitic effects
- Increasing the voltage of the inputs
- Adding buffers to outputs to sub-block outputs to re-assert the logic value on high fan-out nets
I was wondering if I am missing something obvious since I have been looking at this too long? Or should I go ahead with what I listed above? Any input would be great! Thanks!
