djy27
Newbie
Hi all,
First post on this forum, so bear with me.
I am working on a portable RF test module using the following hardware (See attached Diagram: note, I should have drawn an arrow from the Pluto SDR back to the amplifier for the Tx!):
Raspberry Pi 4B (running GNU Radio)
Pluto-ADALM SDR (for signal transmission/reception)
ZX60-V62+ Mini-Circuits RF Power Amplifier (Data Sheet here: https://www.digikey.co.uk/en/produc...hg_bR_cMKidVNUw2t9ea7F16-5fhiSh_C8AvkvR_JX3N1)
Two high-gain SMA antennas connected via the amplifier (Tx Only, Rx Will be for surveying reciprocal test module about 500 metres away) (https://www.getic.com/cart)
GPS Module (GlobalSat BU-353N5: for potential timing synchronization/location-based testing)
Android Tablet (connected via mini-HDMI for control/interface)
ANKER 26800mAh Powerbank (used as the primary power source)
Current Working Setup (Without the RF Amplifier)
So far, I have successfully powered the Raspberry Pi 4B using the ANKER power bank via USB-C.- The Pluto SDR is drawing power via the Raspberry Pi’s USB port, and everything works fine.
- The Android Tablet is connected via mini-HDMI for control, and a GPS module is also connected.
Adding the ZX60-V62+ RF Power Amplifier
Now, I need to power the ZX60-V62+ amplifier, which requires:- 5V DC with a typical current draw of 82mA (max 92mA)
Power Supply Considerations
Option 1: Use Raspberry Pi’s GPIO 5V Pin (
Potential Risk)
Pros: Simple wiring, no extra components.Cons: The Pi’s GPIO pins are not designed for high-current draw and lack overcurrent protection. I’m concerned about potential voltage fluctuations or current limitations affecting stability.
Option 2: Use a USB to 5V Breakout Adapter (
Preferred Option?)
Pros: The RF amplifier gets power directly from the ANKER Powerbank, reducing the load on the Raspberry Pi.Pros: Provides a more stable power source.
Cons: Slightly more complex wiring (requires soldering to the breakout adapter).
Option 3: Use a Dedicated Small Battery Pack (
Separate RF Power)
Pros: Completely isolates RF amplifier power, reducing EMI/noise interference.Cons: Requires an additional small battery pack, adding to the complexity.
My Key Questions for the Community:
I’d love to hear from those with experience in portable RF test setups, SDR systems, and power optimization. Any insights would be greatly appreciated!
Thanks in advance for your help.
