jayanth.devarayanadurga
Banned
- Joined
- Dec 4, 2012
- Messages
- 4,280
- Helped
- 822
- Reputation
- 1,654
- Reaction score
- 791
- Trophy points
- 1,393
- Location
- Bangalore, India
- Activity points
- 0
I have written a code for MCP27X17 I2C Port Expander but it is not working. Can anyone help me fix the code. I have attached the mikroC Project files and Proteus File.
Address of MCP27017 is 0x000 (A0-A2 grounded)
mikroC PRO PIC v6.0.1 C Code
Edit: The problem is solved. It is working now.
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 //Project: Port Expander //MCU: PIC16F877A //Clock: 8 MHz //Author: Jayanth Devarayanadurga #define I2CMODE 1 #define SPIMODE 0 #define WrtCmd 0 #define RdCmd 1 //#defines are with IOCON.BANK = 0 #define IODIRA 0x00 #define IODIRB 0x01 #define IPOLA 0x02 #define IPOLB 0x03 #define GPINTENA 0x04 #define GPINTENB 0x05 #define DEFVALA 0x06 #define DEFVALB 0x07 #define INTCONA 0x08 #define INTCONB 0x09 #define IOCONA 0x0A #define IOCONB 0x0B #define GPPUA 0x0C #define GPPUB 0x0D #define INTFA 0x0E #define INTFB 0x0F #define INTCAPA 0x010 #define INTCAPB 0x011 #define GPIOA 0x012 #define GPIOB 0x013 #define OLATA 0x014 #define OLATB 0x015 #define IORESET PORTC.F4 #define HRDADD 0x00; #define HRDWADD 6 // device hard address unsigned char gAddrPins = HRDWADD <<1; unsigned char SerialMode = I2CMODE; unsigned char gControlByte = 0x40; unsigned char mode = 0; //1 for SPI, 0 for I2C void I2CWriteByte(unsigned char reg, unsigned char data_); void Write23X17(unsigned char reg, unsigned char data_); void ResetMCP23X17(); void InitMCP(void); void ResetMCP23X17(){ IORESET = 0; delay_us(100); //IORESET = 1;; } void SPIWriteByte(unsigned char reg, unsigned char data_) { SPI1_Write(gControlByte | WrtCmd | gAddrPins); SPI1_Write(reg); SPI1_Write(data_); } //**************************************** // I2CWriteByte(unsigned char addr, unsigned char byte) // Writes a byte to the 23017 //**************************************** /************************************************************* Function Name: Write23X17 Return Value: void Parameters: Register address, Data Description: Writes a 23X17 register. I2C or SPI is in global byte **************************************************************/ void Write23X17(unsigned char reg, unsigned char data_) { if(SerialMode == I2CMODE) //If 23017 selected I2CWriteByte(reg, data_); // else //Else 23S17 is selected SPIWriteByte(reg, data_); // } void InitMCP() { //Configure 23017 //Write23X17(GPPUA, 0x00); // Pullups Write23X17(IOCONA, 0x40); // Write23X17(IOCONB, 0x40); Write23X17(IODIRA, 0x00); //All outs Write23X17(IODIRB, 0x00); //All outs } void I2CWriteByte(unsigned char reg, unsigned char data_) { I2C1_Start(); I2C1_Wr(gControlByte | WrtCmd | gAddrPins); I2C1_Wr(reg); I2C1_Wr(data_); I2C1_Stop(); } void main(){ TRISA = TRISB = TRISD = PORTA = PORTB = PORTD = 0x00; TRISC = 0x00; PORTC = 0x00; if(mode == 0) I2C1_Init(100000); else if(mode == 1) SPI1_Init(); InitMCP(); while(1){ Write23X17(GPIOA, 0xAA); } }
