I have simulated EBG structures in Momentum for modifying the radiation properties of patch antennas, with satisfactory results.
I'm not sure what you mean by "phase diagram"; if you're looking to find the reflection phase of a normally incident plane wave, you're out of luck - you can't do this in Momentum.
The dispersion curves can be found by setting up a two-port simulation (one port on the ground plane, one on the patch plane) and using the equation which relates the dispersion (Bd) to the resulting scattering parameters. Just remember to use a good number of EBG cells to keep the results accurate, as Momentum can't simulate an infinite array.
