PonyProg and Atmel AT89S8252
GeneralMadDog
Member level 2
where it smells funny...
at89s8252 parallel programmer
Hi all,
is anybody able to program a Atmel AT89S8252 with PonyProg?
I'm able to program a AT90S8515, but not the AT89S8252.
Now I'm using a simple parallel port programmer which is running under DOS.
Regards
MadDog
Jack// ani
Advanced Member level 3
at89s8252 programmer
Yes I have programmed it....works very well for me. Remember to enable INVERTED RESET in setting menu and you will be able to program AT89S8252.
Hope this helps
GeneralMadDog
Member level 2
at89s8252 ponyprog
Yes, I have taken the polarity of reset signal into account.
What kind of PC, OS and programming adapter do you use?
Jack// ani
pony prog 2000 89s8252
I'm using STK200 cable with WinXP. If you are unable to program it you can use Asim's Kahn "ISP Flash Programmer 3.0a" software to program 89S8252
Hope this helps
samcheetah
Advanced Member level 2
Pakistan
89s8252 programmer
i would highly recommend you Asim Khan's ISP-Flash Programmer. its easy to build and it works!!!!!!
