Poly-Si resistors aging for a ratio
faf
Newbie level 2
Hello,
I find aging figure for poly-Si resistor (variation=0.7% after 300h at 150C), but I don't find any data on variation for a resistor ratio (=variation between both resistor).
Do you have an order of magnitude for resistor ratio aging ?
Thanks
If they are matched well, the ratio should be kept same.
Do you have some experience ? For exemple when you match your resistor ratio at 1 ‰ to have a gain accuracy of 1 ‰ do you think your gain accuracy will be 1‰ after 5 or 10 years ?
I guess but I 'm not sure that the gain will move from 100-1‰ to 100-2‰ for exemple, do you agree ?
thanks
I think it depends on the accuracy and possibility.
In general case, most IC in well design will work for 10 years.
