zlatkoMM
Full Member level 5
Pocket FM radio
Is anyone see this small weirdo before?
Design is very unusual and when i have i will try to build one.
I think that will work also with BF566 VHF pnp transistor.
Original text:
This is the most simple fm radio receiver with good performances that works
great even if the sensitivity is not too high. The working principle of this fm
receiver may seem a little unusual. It is made of an oscillator (T2 and T3) that
is synchronized with the received frequency of T1. This transistor works as a
broadband preamplifier in VHF range.
The oscillator is adjusted between 87 … 108 MHz with C5. Because of the
synchronization, the oscillator output will have the same frequency deviation as
the received signal from the fm antenna. This deviations are caused by the
broadcasted audio informations. The frequency modulated signal show up on P1 +
R5. Low pass filter R6/C6 extracts the audio signal and then is amplifier by T4
… T6 and transmitted at the output through C9 capacitor.
FM Receiver Circuit Diagram
The coil details are presented in the fm receiver circuit diagram. The radio
receiver is adjusted on different stations with the help of C5. P1 potentiometer
is adjusted untill the best reception is obtained. If we attach an audio
amplifier and a speaker then this fm receiver can be made very compact as a
pocket radio.
Original text:
pocket radio.
