PO2L, I can't find it in the LSW(layer select window)
allennlowaton
Full Member level 5
Taiwan
Good day EDA fellows?
I will now create my on-chip resistor.
The problem is I can't find the PO2L layer in the LSW of the Virtuoso.
Though PO2L is in the TSMC 0.35um Design Manual.
Hope you can help me with this.
From the top menu of LSW choose Edit-->Set (or show) Valid Layers.
You will see a big list with all available layers,choose the one you want
and it will appear in LSW.
If you find a layer in the full set that is not in LSW by default, be sure
you are adding a layer that is supported in your specific foundry flow.
Some foundries have a master PDK that serves everything from digital
to mixed signal to RF, but not every feature is available in every sub-
flow.
