PN junction diode Characteristics
rajasekharnbkrist
Junior Member level 2
Explain the meaning of following statement:
As doping increases the contact potential of the PN diode junction increases
ElectroEnigma
Newbie level 1
If two solid conductors are brought into contact, an exchange of electrons takes place between them; at first the electron transfer will occur predominantly from the conductor with a lower work function to the conductor with a higher work function. As a result, the conductors acquire electric charges of opposite sign, which causes the appearance of an electric field that impedes the flow of electrons. Ultimately a state of equilibrium is attained; in this state the electron flow in one direction becomes equal to the flow in the opposite direction, and a contact potential is established between the conductors.
The value of the contact potential is equal to the difference in work functions divided by the charge of an electron.
As doping (i.e. amount of impurity concentration) increases -> free electron-hole concentration increases -> thereby increasing the contact potential
Following page has described it in details.
https://encyclopedia2.thefreedictionary.com/Contact+Potential
