plz help me...PLL designing
mytreyi
Junior Member level 3
india
how to find the values of resistor,capacitors in loop filter...
plz help me....
thanq...
normally pll loop filter design is done using behavioral simulators, there are few available on internet
above link has two such behavioral simulator , may be of some help
Hi
There can be 2 answer to your question:
If you design a discreate PLL circuit you should teak the advice from ankitgarg0312
If you are using an IC pll most of the manufacture provide some application note show you how to design the loop filter
You can try National,Freescale. and analog device for pll application note
Search for MC145170 (not sure whether it is manufactured anymore) the data sheet will show you how to design the loop filter
All the best
Bobi
Is any body aware about the filter designs (i need to have a first order filter and a lead lag filter) to be used in PLL design with LM 565.
Thankx
