Jun 14, 2007 #1 N neoflash Advanced Member level 1 Joined Jul 2, 2005 Messages 492 Helped 10 Reputation 20 Reaction score 2 Trophy points 1,298 Activity points 4,759 4 - 6 bit resolutions are ok. thanks.
Jun 15, 2007 #2 J jfyan Full Member level 2 Joined May 3, 2006 Messages 145 Helped 26 Reputation 52 Reaction score 4 Trophy points 1,298 Location shanghai,china Activity points 2,064 Re: Pls recommend papers on multi-gigasample/s A/D converter neoflash said: 4 - 6 bit resolutions are ok. thanks. Click to expand... hi, i once saw phd's thesis about giga-hz AD used for uwb. i think you can find it from lab publication in UCB. jeff
Jun 15, 2007 #3 raduga_in Full Member level 4 Joined Aug 29, 2005 Messages 199 Helped 32 Reputation 68 Reaction score 10 Trophy points 1,298 Location India's Silicon Vally Activity points 2,357 Sansen and Styart's paper M. Steyaert, and W. Sansen, "A 1.8-V 6-bit flash ADC with rail-to-rail input range in 0.18um CMOS," is a good starting point .. and also you can check the review web.mit.edu/klund/www/papers/UNP_flash.pdf Regards Raduga
