dathoang86
Newbie level 5
I had a FFT, data output is through is real and image. This real and image data is squared, add together and go to square root block.
After that, we have 16 bits unsigned fix point.
But in software, i don't know to convert data to dB.
Example, i transmit a -60dBm from the signal generator through a cable, i want to see this signal peak in my software is -60dBm, the maximum display in dB is 0 dBm, the minimum is -140 dBm.
pls help me what i need to do, or give me some documents.
Thanks,
Dat
Thanks,
Dat
