Plotting graph in C, displaying variables
JoKKeR
Full Member level 2
Estonia
Hi !
Im working on a embedded systems. Wring code in c.
How to display variables on plots.
For example DEV cpp compiler.
Maybe there are some-kind of libraries ... .h files which will help me out :S
Thank you !
Added after 40 minutes:
Well ... im asking a question and answering it ;)
Theres a software called "DSLIN" It is free for non-commercial use.
Still ... cant create a plot.
Im looking for a .h file with some functions in to display variables on 2d.
That's a platform-specific question. What is your environment ? Windows ? Linux ?
In order to display something you'll have to use a graphic library. I used to do this with SDL. Now I'm doing this in C# under windows with the help of zedgraph.
Regards,
Franck.
you can use a library called "koolplot" or a C compiler called QuincyC 2005 where "koolplot" is built in, both are free to download, you can use "koolplot" with dev C++ to create graphs.
good luck
Miniscope v3 has simple OpenGL based graph module. This is Turbo C++ Explorer project - this IDE is free.
Earlier versions may be easier to modify than new ones (no interface to real measurement devices included yet).
