Plotting energy and power in MATLAB
Sean87
Newbie level 6
Netherlands
Hi all,
Maybe this is a noob question but I just started working with MATLAB and really no big idea on how to use its commands and functions.
I have a AC circuit with following equations:
plotting the voltage, current and power wasn't that hard (I think I wrote the correct code, please tell me if you think it's wrong!):
%Variables
t1=20e-3;t2=60e-3;N=1000;f=50;
t=linspace(t1,t2,N);
Vmax = 10; %Peak Voltage
Imax = 2; %Peak Current
f = 50; %Frequency in Hertz
omega = 2 * pi * f;
phi_default = -pi/4; %Constant for phase difference
%Equations
Vsrc = Vmax * sin(omega * t); %Equation for Voltage
Isrc = Imax * sin((omega * t) + phi_default); %Equation for Current
Psrc = Vsrc .* Isrc; %Equation for Power
%Plotting the result
figure(1); %Window 1
plot(t,Vsrc, 'b', t, Isrc, 'r', t, Psrc, 'g'); %Plotting Voltage, Current and Power
Now the problem is that I can't figure out a way to plot Energy in matlab. I think Δt (Delta t) should be defined maybe using diff(t) function and total energy should be something like:
And average power Pavr is calculated by \[\frac{ Wtot}{T}\] Where T is period.
So the question is, how can I plot the total instantaneous energy as a function of phase difference in range for this I think a for loop should be necessery to calculate for each phase value.
Also I want to plot the average power in the same period.
Thanks in advance for tips and tricks!
