Plotting E and H field in HFSS (2D Radiation pattern)
vijaimvk
Newbie level 5
Newbie level 5
I am Using HFSS 9.2
This is my 3D radiation pattern
Hence I expect figure of 8 in XZ plane and circle in XY plane
for x plane i followed the steps as shown in below pictures.
But not getting proper result...
For XZ plane
Changed angle as theta,
Under Sweeps tab selected Phi=0,
If this is wrong ..plz suggest corrections
Hi vijaimvk,
I'm not sure what you're trying to do. You can plot 2D plots by selecting Far Fields Report -> Radiation Pattern. You can then plot vs theta or phi, selecting the cut angles with the "families" tab.
Good Luck
Hi vijaimvk,
Good Luck
As in the above images, there is only 3 tabs.. ..Antenna oriented in the XZ plane ... hence my E plane is xz plane and H plane is xy plane..
hence for XZ plane I set phi=0 deg and theta = all ,and theta as primary sweep .
for XY plane I set theta =90 deg and phi= all, and phi as primary sweep ..
But not getting them correctly ..... plz help
