Hi;
I designed a LC-VCO in ADS and i should plot its phase noise. I persued a clear Tutorial so i used HB simulation. I will send the ADS file of output voltage and the parameter which i used in HB simulation to undestand more the matter. After doing all of these steps, i can't plot the phase noise spectrum. What can i do and how can i solve this matter. I ask if the matter in the offset frequency or in another parameter in HB simulation.
I have designed an LC-VCO at frequency 12.8 GHZ and i would like to plot the phase noise. I used a tutorial to do this. However, when i run simulation i can’t plot the phase noise spectrum, as it is clear that the curve it is usually zero. I would like to know the matter that evoid to plot the curve.
Hi;
