plot 2D radiation pattern
math_daoud
Junior Member level 1
Dear All
i have data from an expremental mesure of a patch antenna (txt file).ther are lots informations in this file, please how can i plot 2D radiation pattern in matlab or origin.
Thank you
sree479
Member level 2
nagpur
Dear math,
Just convert the angle information from degrees to radians. then plot it in matlab using polar plot command. you will get the desired 2D Radiation pattern plot.
math_daoud
Dear sree479
thanks for your answer
but, I do not know how to do this, as I said there is a lot of information in this file .
here is a part of the txt file
can you help me?
hagster
Member level 4
Or use Octave as a free alternative to matlab. It runs most matlab scripts without modification and there is now a Windows build too.
membran
Newbie level 6
Matlab provides a lot of functions to accomplish the task you're asking about. I would use the function "textread()", where you can clearly specify how the data in your file is arranged. It then gets read into variables for further processing. You may find out more about this function by typing "doc textread" into matlab or looking it up on the internet. After that, just use a plot function, e.g. "polar", to plot the pattern.
M
Nano_o
Member level 2
Dear sree479
can you help me?
Hello,
I am unable to see the text file , did you upload it ?
sree479
Member level 2
nagpur
Dear math,
You have to convert the degrees data to radians by multiplying the degrees data with pi/180, then plot the polar plot using radians data and gain data in dB.
