[SOLVED] PLECS: Steady state not achieved
CataM
Madrid, Spain
Hello everyone,
I am unable to achieve the steady-state of the converter attached in PLECS. A bit of explanation about the converter is here.
Running a transient simulation, I see that steady-state is achieved starting at about 1.45*10^(-2) seconds (Cout initial voltage set to 12 V).
I set the parameters for the steady state as follows:
Since Vout freq is 200kHz => system period: 5e-6
Number of init cycles: 1.45*10^(-2)*200kHz=2900
Are these settings reasonable ?
Should I run the simulation with only one scope (the scope from the output) so that the simulation focuses on the output ?
P.D.: Notice that I am running the converter without the voltage regulation around CMC.
Any hint or comment is appreciated.
  • PSFB-Gvc.rar
I simulated for more time in transient simulation and the steady state is clearly reached.
I changed Number of init cycles to: 2.8*10^(-2)*200 kHz=5600, but still the same message:
Steady state failed to converge after 20 iterations
I feel it is something wrong with my Steady-State simulation setup, but I do not know what.
I finally solved it via making this change in the simulation setup:
*Changed "system period" from 5*10^(-6) which corresponds to the filter inductor's period to 10^(-5) which corresponds to the XFORMER's period.
Simulation reaches steady state very fast and also, no need for thousands of "init cycles", just with 20 works well.
Reactions: FvM
    FvM
