Register Log in
Please I'm new to microcontroller programming in assembly language
Jhamiu
Newbie level 5
Pls im new to Microcontroller programing in assembly language
I need to code to program pic16f84a to increament from 0 to a number(like 11), when it reaches the highest number, it go back again and the increament are display using two seven segment display
pjmelect
Advanced Member level 2
Re: Pls im new to Microcontroller programing in assembly language
What language? hardware circuit needed.
Jhamiu
Newbie level 5
Hardware needed are microcontroller, push button, two 7 segment display using assembly language.
Jhamiu
Newbie level 5
Hardware: pic 16f84a, push button, two 7 segment display
language type: assembly language
KlausST
Super Moderator
Staff member
Please try to give all informations at once, not piece by piece.
How are the pushbuttons connected, to which port pins?
How is the 7segment connected, multiplexed, direct, with driver IC?
Klaus
Jhamiu
Newbie level 5
It is multiplexed
No driver ic
1 push button connected to port Ra3
7segment pin are connected to port Rbo to Rb6
Only 1 Push button is used and is connected to RA3 port
The pins of of 7segment display is connected to port RB0 to RB6 and they are multiplexed without ic.
Pls you can also use ur own connection the main thing is that pic16f84a, 1 push button, and two seven segment display multiplexed is used.
KlausST
Super Moderator
Staff member
Hi
Sorry...but now I have to assume that you just look for someone to do your job.
Not only program anymore...now additionally schematic.
And device selection...calculate device values..
Please show us what you have done so far.
Klaus
Okada
Banned
I can only give C code but I can also give compiler generated asm code. Is it ok ?
Jhamiu
Newbie level 5
Ok, i will like that
Toggle Sidebar
