PLEASE Help with SERVO motor : NOT WORKING !!
nikhilsigma
Full Member level 2
Delhi, India
Guy i am trying to make my servo RKI-1210 work, but it's NOT working......
i am sending control pulses at 50Hz i.e. a pulse every 20ms...
the pulse widths are as follows :
-90degrees : 1.5ms
normal position : 2ms
+90degrees : 2.4ms
i get these from others discussions on internet, and thus NOT sure that these are right or not !! :-(
here is the code i am using for ATmega32
#include <avr/io.h>
#define F_CPU 1000000UL // 1MHz
#include <util/delay.h>
int main(void)
DDRB=0xFF;
PORTB=0xFF;
int i,j,k;
while(1)
for(i=0; i<1000; i++) // for -90degrees, pulse of 1.5ms pulse
PORTB=0xFF;
_delay_us(1500);
PORTB=0;
_delay_us(18500);
for(j=0; j<1000; j++) // for normal position, 2ms pulse
PORTB=0xFF;
_delay_us(2000);
PORTB=0;
_delay_us(18000);
for(k=0; k<2000; k++) // for +90 degrees, 2.4ms pulse
PORTB=0xFF;
_delay_us(2400);
PORTB=0;
_delay_ms(17600);
and the motor has not moved even 1degree !! he he.... :-(
PLEASE HELP !!
Hardware connection :
RED Wire : 5V
Brown Wire : Ground
Orange wire : PORTB.4 of atmega32
PLEASE HELP !!
Normally servo pulses are like this:
But 0deg. can be 1.00ms and 180deg. 2.00ms
Mid.pos. should normally be 1.50ms
Refresh 20ms ( can be 15....40ms)
citation from another site: Futaba will need 0.25 to 2.50 ms, Graupner will need 0.6 to 2.4 ms ...
Are you sure servo get those pulses.............
your loop time 0...1000 = 20sec.
Are you your pulses in servo wire have right timing.
KAK
Yes I am 98% sure that servo might be getting those pulses.....
because i had programmed that port with same program( having high duty cycle, as with current program the duty cycle is too low) and have checked that on LED and it was working great....(rest i am not sure it to be exactly accurate, as i can't measure it).....
and my loop time is 20ms x 1000 i.e. 20 seconds.....
i have two brand new servo motors of same type, but both are not working :-( so there isn't any problem in servos....
so what's the exact problem...?? is there any problem in program, any idea.....
also there is no problem, if the servo can't go completely from -90 to +90........the main problem is that the servo isn't moved a degree......
i ain't getting anything....
---------- Post added at 20:27 ---------- Previous post was at 20:18 ----------
hey guys check out this....i found a almost same problem as mine.....but mine still not working even with his solution.... :-(
connecting a pwm servo(RKI 1210 aka HS311) to pic16f877a
and here is the link to the servo motor i am using.....
Standard Dual Ball Bearing Servo [RKI-1210] - Rs.525 : Robokits India, Easy to Use, Versatile Robotics Kits...
Can you check that atmega is giving proper TTL pulses to servo.
Pulsed between 0 to 5Volt
Servo supply is 5V or higher
Motor and controller have same ground potential
Test refresh timing 40ms and 10ms
i think 1.5ms is right time for midpos.
but turn cw and ccw pulse times can vary by manufacturer and type.
Data sheet say that is direct compatible with
Hitec HS-311.
Pulse Cycle: 20 ms
Pulse Width: 900-2100 µs
KAK
I am so stupid.....the main problem was of power supply for motor.... it was not enough.... he he :p
Thanks dude for all the help....
