I need help to identify the component on the attached foto.
What type of component, and the specifications of the color bands?
Info: The component is mounted in a circuit that controls a 230 VAC fan.
It's a MELF (SOD80) diode. The color bands match the BB215 but that is a special pupose tuning diode and the photograph suggests it's in power circuit of some kind.
The relatively high value of the resistor in series with it suggests it isn't a high current rated diode, possibly a Zener or high voltage type.
I've been in the industry for half a century and have no idea what an OEO is.
I think I've tracked the part down as a 1N6482 from Vishay. It seems to be appropriate for the board it is fitted to and it has the correct color bands.
Try here for the data sheet: https://www.vishay.com/doc?88527
