please help me some Quizs in syntax VHDL ?
gunnerunbeaten
Member level 2
-----Quiz 1
Determine whether the relational operation is syntactically correct. If yes, what
is the result (i.e., true or false)?
(a) "0110" > “1001”
(b) "0110" > "000"
(c) 2#1010# > "1010"
(d) 1010 > "1010"
case1 : assume that the data type is unsigned
case2 : assume that the data type is signed
-----Quiz 2
Determine whether the following signal assignment is syntactically correct. If not,
use the proper conversion function and type casting to correct the problem.
library ieee ;
use ieee.std_logic_1164. all ;
use ieee.numeric_std. all ;
signal s1, s2, s3, 94, s5, s6, s7: std_logic_vector(3 downto 0);
signal u1, u2, u3, u4, u5, u6, u7: unsigned(3 downto 0);
signal sg: signed(3 downto 0) ;
U1 <= 2#0001#;
u2 <= u3 and u4;
U5 <= s1 + 1;
u6 <= u3 + u4 + 3;
u7 <= (others=>'1');
s2 <= s3 + s4 -1;
s5 <= (others=>'1');
s6 <= u3 and u4;
sg <= u3 - 1;
s7 <= not sg;
------------ thanks ---------
hey,
Why dont you try.. and post your views.. on these questions.. so that we can help you..
Posting questions like this is not a good way to learn.
Thanks for providing the brain teaser! I thought I knew the answer to all the quiz questions except for the ones with expressions like 2#0001# in it. So thanks to your lazy homework I googled it and found out how based literals work in vhdl, thanks! So now I think I know all the answers for this quiz. w00t! progress!
Turns out that in a convoluted way it was. Just not for him. :p
thanks ! please check for me :
Quiz 1 :
+ case data type is unsigned :
a. "0110" > "1001" : syntax correct , result : false ( 6 > 9)
b. "0110" > "0001001" : syntax correct , result : false ( 6 > 9)
c. 2#1010# > "1010" : ? ( i dont know)
d. 1010 > "1010" : ? ( i dont know)
+ case data type signed :
a. "0110" > "1001" : syntax correct , result : true ( 6 > -7)
Quiz2 :
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
signal s1, s2, s3, s4, s5, s6, s7: std_logic_vector(3 downto 0);
U1 <= 2#0001#; -- error -- edited : U1 <= to_unsigned (2#0001#,4);
u2 <= u3 and u4; -- correct
U5 <= s1 + 1; -- error -- edited : U5 <= unsigned(s1) + 1;
u6 <= u3 + u4 + 3; -- correct
u7 <= (others=>'1'); -- correct
s2 <= s3 + s4 -1; -- error -- edited : s2 <= std_logic_vector(unsigned (s3) + unsigned (s4) -1);
s5 <= (others=>'1'); -- correct
s6 <= u3 and u4 ; -- error -- edited : s6 <= std_logic_vector(u3 and u4);
sg <= u3 - 1; -- error -- edited : sg <= signed(u3) - 1;
s7 <= not sg; -- error -- edited : s7 <= not std_logic_vector(sg);
please help me check answers and complete miss .
For c) google on "vhdl based literals". And with a bit of luck you'll read about literals in general which magically solves d) for you as well. :)
c. 2#1010# > "1010" : syntax correct : result : false ( 10 > 10 )
d. 1010 > "1010" : error
c. 2#1010# > "1010" : syntax correct : result true ( 10 > -6)
-- are these right ?
1010 is just an integer (one thousand and ten), and you can compare an integer to a signed/unsigned.
PS. Hurray for a lecturer who uses numeric_std. I never thought Id see the day.
So, there is no error in Quiz 1 ?????
I think 1.d is syntactically correct, so then your answer of "error" would be in error.
PS. Hurray for a lecturer who uses numeric_std. I never thought Id see the day.[/QUOTE]
Hello Tricky.. I have a question regarding the use of numeric_std.all, I don't know why its not recommended, may be because it needs type conversion , or its not recommended because of portability issues of the code... I really don't know.
But I use it at times when I need to do operation on both unsigned and signed data types, and its easier to do the conversion, than fighting with the ambiguities of std_logic_signed.all package and std_logic_unsigned.ll package..
What should be the right thing to do? and why is numeric_std package not recommended?
Thanks for your help in advance...
numeric_std IS recommended. And it is also an IEEE standard.
Thanks tricky.. sorry I misunderstood your comment...
