NIKO BELLIC
Newbie level 6
- Joined
- Aug 1, 2011
- Messages
- 14
- Helped
- 6
- Reputation
- 12
- Reaction score
- 5
- Trophy points
- 1,283
- Location
- Kansas City, MO
- Activity points
- 1,389
Hi all,
Please someone help me...!! I'm facing a glitch in displaying the time on 4 seven segment LEDs using ATmega 16. Recently, I've learned how to count numbers from 00 to 99 on two 7 segment LEDs using multiplexing technique. So, to step further, I decided to write a program to display time (digital clock for max 1hr). My simple logic behind the code is that, if seconds reaches to 59, then reset seconds and increment minutes and continue counting seconds. I've faced few bugs at first and after clearing all of them, I could not see the output what I expected. After reaching 59 seconds, instead of showing 01 in minutes block, it is showing 59...!!?
My code...:
Proteus Design file...
My code...:
// This program starts counting the time on power up...
// Microcontroller : ATmega 16
// Compiler : WinAVR - 20100110
// Language : C
#include <avr/io.h>
#include <util/delay.h>
void main (void)
// Initialization of ports
DDRA=0xFF;
DDRB=0xFF;
unsigned int values[10]={0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90}; // Includes numbers from 0 to 9
unsigned int seconds,var1,num1,num2,num3,num4,var2,minutes;
for(seconds=0;seconds<60;seconds++)
var1=seconds;
num1=var1%10; // Extracting Units place of seconds
var1=var1-num1;
var1=var1/10;
num2=var1%10; // Extracting tens place of seconds
var1=var1-num1;
var1=var1/10;
for(int i=0;i<5;i++) // Delay between two consective counts
PORTB=(1<<PB0)|(0<<PB1); // Turning ON Units place of seconds
PORTA=values[num1]; // Writing corresponding number on Units place of seconds
_delay_ms(5); // Very short delay
PORTB=(0<<PB0)|(1<<PB1); // Turning ON Tens place and Turning OFF Units place of seconds
PORTA=values[num2]; // Writing corresponding number on Tens place of seconds
_delay_ms(5); // Very Short delay
if (seconds==59) // Checking condition that if seconds = 59
seconds=0; // Resetting seconds value to 00
for(minutes=1;minutes<60;minutes++)
var2=minutes;
num3=var2%10; // Extracting Units place of minutes
var2=var2-num3;
var2=var2/10;
num4=var2%10; // Extracting Tens place of minutes
var2=var2-num4;
var2=var2/10;
PORTB=(1<<PB2)|(0<<PB3); // Turning ON Units place of minutes
PORTA=values[num3]; // Writing corresponding number on Units place of minutes
PORTB=(0<<PB2)|(1<<PB3); // Turning ON Tens place and Turning OFF Units place of minutes
PORTA=values[num4]; // Writing corresponding number on Tens place of minutes
