You can use a PIC18F97J60, which has a built-in ethernet interface, an external ethernet controller, e.g. ENC28J60, or a Wiznet controller (e.g. W5100) with hardware TCP/IP stack.
that means external phy transceiver is not required.right!PIC18F97J60 family is the only single chip solution available from Microchip, PIC18 with built-in ethernet MAC and PHY.
Right, you need only rj45 connector with magnetic (magjack) and a few resistors and capacitors.that means external phy transceiver is not required.right!
thank for reply... xport is a new word to me...i googled it and came to it is inside rj45 and that will take your serial data stream and convert it to Ethernet packets. i want to know more about it can suggest any particular web site or reference schematic.You can also use Xport. Easy to use for Network Ethernet connectivity.
Best Regards,
Siong Boon
NO SIGNATURE LINKS ALLOWED
