please help -> DC Motor Control
rated_pg
Newbie level 5
hello guys
i need your help in designing a dc motor control. the motor should function forward and reverse.
thanks
What kind of DC motor? Which voltage and current? Just forward and reverse or variable speed from 0 to 100% or any other range?
Hi, rated_pg
simply You can use a relay with enougth (two) contacts groups to revers voltage polarity from power suplay... if You want to do control using electronic (microcontroler) You must use two relays: one of them can change polarity for DC motor and another is for connecting suplay voltage...
Best regards.
You visit this link **broken link removed**
They have goods schematic
Hi
u can use a H bridge circuit for DC motor control with 2 digital
line.
with this kind of driver u can control direction & motor speed(PWM)
& u can add a brake ,control with this 2 digits
if u have any question ask me
thanks for the help guys!!!
by the way the motor should function forward and reverse the speed is not much of a consideration
