I can help you if you zip and upload the schematic of your project. What sensor are you using and what compiler?
Do you want something like this.
Please find the attachment.
I need to modify the schematic by replacing the PICAXE with PIC18F452. And the code is found from edaboard.com i mentioned previous reply..
Thanks.
Yes. I need a conversion like you post. I will also need to display in PC with a data logger (i m trying with stamp plot). I also got some help from a friend... he send me the below code:
unsigned int temp_res;
unsigned char text[6];
void main()
int len=0;
UART1_Init(9600); // Initialize UART module at 9600 bps
Delay_ms(100); // Wait for UART module to stabilize
do
temp_res = ADC_Read(2); // Get 10-bit results of AD conversion
if(temp_res>999)
len = 1;
else if(temp_res<1000 && temp_res>99)
len = 2;
else if(temp_res<100 && temp_res>9)
len = 3;
else
len = 4;
WordToStr(temp_res,text);
UART1_Write_Text(text+len);
UART1_Write(13);
Delay_ms(1000);
} while(1);
with mikro c i compiled this to hex with no error. Then loaded to MCU. I m using a dev board for PIC18F452.
Any more help from you is highly appreciated.
Thanks.
