Please generate a NC drill file for me
billano786
Super Member
I have a pcb file in p-cad v 4.5. I don't have p-cad to open it. Can anyone generate its ncdrill file for me?
Awarapunshee
Advanced Member level 1
Some Where In Heaven
nc drill file format
I have converted your file in PCAD2002, Now you can easily edit it and make the gerber, drill file etc as required.
ENJOY!
billano786
Super Member
p-cad 2002 translate
Back to square. I don't have P-cad 2002. Can anyone generate NCdrill file and help?
House_Cat
USA
view drillfile
To generate the NCDrill file will require someone with the old DOS PCAD 4.5. When you convert the file to PDIF format, the hole sizes are lost, and the only way to process the file in newer formats is to convert it to PDIF.
If you're willing to go through the file and edit the PCB hole sizes, I can convert your file into almost any format so you can view and process it as you like. Just tell me what format you prefer.
An alternative would be if you have a Gerber file with the drill table displayed, or a "TBL" file for your PCB. That table could easily be used to restore the holes lost in the PDIF translation, and that would make the NCDrill file production very easy.
billano786
Super Member
nc drill table
Can you make it Altium compatible? Then I can do what I want.
House_Cat
USA
Re: Need NC drill file
Sure - no problem. What version?
Reactions: LIMAN
    LIMAN
billano786
Super Member
Altium DXP will be fine.
House_Cat
USA
Here's your converted file. Keep in mind that the hole sizes are just guesses. In order to translate a PCAD4.5 file to anything else, it has first to be saved in PDIF format. That format loses the hole size information unless you also have a drill table file that was produced in PCAD4.5 (that file has a "TBL" file extension).
My advice is to proceed carefully. The other thing to watch for would be the design rules. They vary greatly between different EDA software.
billano786
Super Member
Thanx, no problems now.
